Selling everything I have left!! Two complete 9"Ford third members, 31 spline spool 6:33 & 5:14 ratio's.($300 each) One 9"Ford center chunk.($50)
Four 9"Ford Ring & Pinion sets, ratio's 4:00, 4:11, 5:29, & 6:14.($100 each)
Two 9"Ford 31 spline spools.($50 each) Lots of sway bars, tubular upper control arms, weld on brackets/spring mounts, wedge bolts, and ballast weights.($100 for all) Three 4 barrel Intake Manifolds, one aluminum, two cast iron.($25 each) One set SBC Vortec cylinder heads 1.94 valves w/all valve train and valve covers.($100) One set SBC GM factory 1.94 heads W/all valve train and valve covers.($100) Scorpion SBC 1.5 roller rockers(Brand new $100) Spring rate tester w/jack($100). Two 15" Kirkey racing seats w/covers and supports.($100 each) Wilwood/Tilton Complete dual master cylinder set up w/pedal and cable adjuster ($200 brand new never been out of boxes) One Longacre Tire temp. gauge($25) One 2 barrel Holley carb. w/4BBL adaptor plate($100) One black medium size Simpson race suit(Worn maybe 5 times $50) Lots of Bassett and IMCA wheels, all 5 on 5, 8 & 10"($25 each) One SBC 358c.i. Engine, 4 Bolt Main, Flat Top Pistons, World Heads, Hydraulic Comp Cam .500 lift, Roller Rockers, HEI MSD Distributor and MSD Plug Wires, Brand New Bo-Laws 650CFM 4BBL Carb, High Torque Starter, and large Oil Pan. Engine is complete w/Water Pump, Alternator, P.S. Pump and Aluminum Pullies.($2500)
One SBC stroked 383c.i. Engine, 2.02 Ported Double Hump Heads, 13:1 compression, 1.5 Roller Rockers, Stud Girdles, Edelbrock Intake, 750CFM 4BBL Quick Fuel Carb., BLP Valve Covers, 9QT oil pan, and Holley High Pressure Fuel Pump. Alternator, Water Pump, P.S. Pump and Fan is on Engine and is a serpentine belt set up. No Distributor($2500) Please contact John @ 321-239-3659. All items in Orlando, Fl 32806.
