Lots Of Good Quality New And Used Parts And Much More
  • Lots Of Good Quality New And Used Parts And Much More
    1 used tiger q/c w/detroit locker. polished lightened r/p w/steel w/5 tubes. was in a 2010 port city big spring car . $1500
    1 used tiger q/c w/detroit locker polished lightened r/p w/alum w/5 tubes rs is bent. was in a 2009 porty city coil over car. $1500
    1 used benson q/c no spool w/alum 5x5 tubes $300
    1 used ford 9" 275 r/p $110
    1 used ford 9" 350 r/p $110
    1 used ford 9" 411 ford motorsports r/p $200
    1 used ford 9" 456 g force rem polished r/p $350
    1 used ford 9" 600 r/p $110
    1 used ford 9" 620 r/p $100
    1 new ford 9" 650 g force polished lightened r/p $500
    1 used ford 9" grandnational snouts 61" snout to snout was in a metric car $300
    1 used ford 9" grandnational snouts 58" snout to snout nickle coated was in a cot car $500
    1 used just re built muncie 4 speed tranny with hurts shifter 24" center of shifter to front tranny face $700 obo
    1 quarter master pro series 4.5 complete triple disk only 12 laps on it $750
    1 used quarter master pro series 7 1/4 complete triple disk w/reverse ring gear $275 [will separate ring gear ]
    1 used quarter master v drive 7 1/4 complete triple disk w/reverse ring gear $375 [will separate ring gear]
    1 used tilton 5 1/2 triple disk for chevy crate $175
    1 used pair port city 5x5 alum hubs w/ bearings races low drag seals $250
    1 used pair wilwood w/5 hubs w/rotors bearings seals and drive flanges $300
    1 used set wilwood w/5 hubs complete with bearing races seals ap j hook front rotors lw rear rotors dust covers and drive flanges $ 650
    1 new pair wilwood w/5 hubs w/races $185
    2 used detroit lockers $300 ea or $500 for both
    2 used dpi black gold lockers $300 ea or $400 for both
    1 used alum tripple track low laps $400
    1 new winters track $500
    1 used pair pfc alum floating rotor hats with rotors $250
    1 used wilwood hanging pedal assembly $125
    1 used pair wilwood 6 piston front calipers $450
    1 used butler built dry sump tank with o berg built in on top $200
    1 used atl plastic bladder 15 gal fuel cell no can 23 3/4L 17 1/8W 9 1/8D $125
    1 used atl bladder fuel cell no can 33 1/2L 17W 9D $400
    1 new fuel safe sportsman bladder fuel cell no can 34L 18W 9 1/2D $600
    1 used empty fire bottle $30
    1 new c&r 31x19 double bypass radiator $310
    1 used pair of bow tie head done by hammner racing engines. t&d shaft rocker system manley valves isky tool room valve springs
    edelbrock intake and valve covers $1200
    1 used 5 star cold airbox $100
    10 used w/5 basset chrome wheels 6 4" offset 4 5" offset $35 each or $300 for all 10
    1 new howe/allstar adjustable camaro center link $170
    2 jrz double adjustable canister shocks 7" stroke $900
    4 used coleman spindles 3 rf spindles 1 is bent 1 lf make offer.
    3 new rs tubular port city camaro/impala/caprice big spring lower aframes w/ threaded balljoint cup. $120 ea or $300 for all 3
    2 new ls tubular port city camaro/impala/caprice big spring lower aframes w/ threaded balljoint cup $120 ea or 200 for both
    3 new rs camaro/impala/caprice lower aframes w/shock mounts and threaded balljoint inserts $150 ea or $375 for all 3
    2 used ls camaro/impala/caprice lower aframes w/shock mounts threaded balljoint insert and mono balls w/spacers $125 each or $200 for both
    2 new afco rebuild kits BBTWIN 1 BBTWIN 2 $300
    Call checkered flag racing @ 305 769 3919 or email us at cfrrace@att.net
