1)Complete set used Esslinger 2pc Rocker Arms and set used mouse traps
little to no wear on pads.........$100
2)6-7 used 2pc Esslinger Rockers with little wear $8 each, buy 1 or all
3)2 Esslinger square teeth Cam degree wheels. Both have some wear on
teeth but still work fine....$25 each
4) Left and Right Pinto spindles $50 for set
5)2 trans 214 second gear ,no shifter OR bellhousing.........$75 each
6)2.3 Canton style racing front sump oil pan**no pickup tube*...$75.00
7)2 stock Mustang 2.3 rear sump oil pans....$5 each
8)4 Esslinger EFI carb adapters 7/8",1",11/2",2"......$45 each
9)10 intakes, carb and EFI..stock..........$15 each
10)Esslinger big tube header,1 runner has been cracked and wielded..$25
11)3 30 over 5.7 Manley rods w/race eng pistons,2" chevy small end...
$50 each or $125 for all 3.
12)3 30 over 5.83 manley rods with race eng pistons,2" chevy small end....
13)Ford motorsports alum valve cover....$15
14)Set used ARP head stud kit.......$50
15)Set main strap kit without bolts......$25
16)Eastbay legal flywheel w/bolt pattern for 71/2"clutch or big clutch..$50
17)Like new crane 510lift 300 dur. solid cam shaft......$75
18)Like new bullet 535 lift solid cam......$75
19)Esslinger bullet ax. shaft***needs dist.gear replaced......$35
20)Race Eng alum ax. shaft gear.......$35
21)Like new 293 8"ring-n- pinion set.....$50
22)Complete 8"chunk w/340 gear, been setting bearings rough....$50
23)2 8"rear housings,1 w/spring pads, 1 pads cut off......$20 each
24)Esslinger power alum crank pulleys 1 and 2 groove.....$20 each
25)Used Esslinger high torque starter new $239,will take $50
Lots of small parts
Sold car now time to clean shop. Will send pics on request.....
WILL ALSO TRADE FOR SBC PARTS..........
Lots of small parts
