Complete minus carb, Mike Riley Chevy dry sump late model engine, in car at this time and can hear it run. Dry sump system included or will separate. Run 3 races. Reduced to $10,000. obo
1.5 Crane energizers rockers with poly locks. $125.00 (never ran)
1.5/1.6 PRW rockers with poly locks $60.00
1.5/1.6 crower rockers $100.
Stud girdle Moroso $50
Pete Jackson timing gear drives (have Two) $60.00 each or $100.00 for two
Two sets of trick flow 80 wall 5/16 push rods 8.000 and 7.800 lengths $60.00 each
Stock GM 400 balancer $30.00
Steel valve covers 3`1/2” tall $30.00
Stock GM 400 oil pan $20.00
Stock GM 400 crank new machine work cut 30 mains 30 rods has new bearings with it $120.00
Crane flat tappet Cam part #F-260/3634 25-6-NC with lifters (used) $100.00
Several other cams also.
.GM 10 bolt rear end, 60" flange to flange, C clip eliminators, 5:12 Richmond gears, summers brothers racing axels, 5x4-3/4, metric GM disc brake mounts. $250
Spraker Racing built GN Ford nine floater inch rear end, 60" flange to flange, has Axles, GM metric brake mounts, 5 on 5 winters hubs with rotors. $325.00
Nine inch gear chunk (650 gear) (Jim Roberts built) $400
Quartermaster 7-1/4 triple disk clutch in good condition $300.00
Older style Quartermaster triple disk $75.00
New in box Hawk Brake Pads (Blacks) $30
Steel Valve Covers $20
Aluminum Valve covers $50
Sweet Rack And Pinion $100
Pinto Spindles $100 for each set, I have two sets
Several wide five sweet spindles $100.00 each
Alum Racing brake drums $20
Schoenfield headers Part# 155 were off dirt LLM Camaro Stock clip 1-5/8 tubes 3” collector $100 almost new
Steel Gm Heads:
0 laps, double hump heads with valves, springs ,guide plates, and rocker studs $400.00
One 338882 Bare head $25
One 3947041 Bare Head $30
One 3970126 Bare head $25
Comp Cam part # 12-327-5 .525 Lift/ .253 Dur. $30
Sweet Steering Box 16-1 $200
Sweet Alum steering wheel $25
all prices negotiable, trades welcome. I'm in Holly Hill near Daytona.
386-547-8213 I can text pics if needed
Steel Gm Heads:
