Has world legal heads has eagle crank with 5.7 I beam bushed eagle rods millennium bolts clevite coated h- bearings has JE pistons and rings. Performer intake Moroso oil pump. Kevco pan with inspection hole and also oil temp bung milodon windbags tray and arp studs.pistons are.008 in the hole. Torrington bearing timing chain Stewart pump, comp products pulleys, has top and lower cooling lines already complete. Cam is Hutter grind and will cam doctor correctly within specs for legality. Can give built sheet with all measurements on final payments. Have 4412 or 3310. DUI distributor. $4500. Complete
Chris 386-837-8048
Chris 386-837-8048
