New Dart 215 Iron Eagle heads, 64 cc, 2.055/1.6 valves, springs good for up to .650 lift. complete everything brand new still in boxes. Never been bolted on a motor $850 obo
Comp Aluminum 7/16 Roller Rocker arms 1.5-1.6 split ratio with stud girdles $130 obo
Comp Stainless 3/8 Steel Roller Rocker arms 1.5 ratio $100 obo
062 Vortec heads 2.02/1.6 valves solid lift valve springs, cut to 62cc they need screw in studs installed. $350 obo
64" offset 9" ford rear end housing with hubs, axles, trailing arm brackets $225 obo
GM 7.5 10 bolt rearend parts, several gears, 3.42, 3.23, 3.08 stock carriers. Make offer
GM 7.5 10 bolt Detroit Locker $300
4 Mosier Axles to fit GM 7.5 10 bolt, 5x5 bolt pattern. $125 per axle
New Kirkey Full Containment seat, was a display model for the PRI and IMIS show. retail is $3000 will take $1100 obo very nice seat
Pictures available, possibly willing to do some trading on a Single Stage External oil pump, Weaver, Stock Car Products, Peterson, Moroso. Everything is located in Huntsville AL.
Call or text Chris at 256-655-7109
