Mini/Mod Mini Parts 4 Sale
  • Mini/Mod Mini Parts 4 Sale
    MAKE OFFER ON ANY OR ALL!!!!!
    2"POLY Holley to EFI intake adapter
    1 high torque 2300 starter w/cable stud stripped
    2 2300 large jurn cranks**need polished**surface rust from setting on shelf*
    1 set 40 pistons and rods
    1 set Ranger motor mounts
    1 new stock looking after market cross member w/weight jack buckets
    1 new set Boyd front frame rails
    Pinto L/F caliper
    1 set new neo bushings for upper Pinto A-Frames
    1 set used lower Pinto A-Frames
    3-4 set used Pinto upper A-Frames
    1 under chassis Pinto Header
    1 under chassis Mustang header
    3 stock rear sump Mustang oil pans**steel**
    3 2300 used fuel pumps
    1 2300 stock thromostat housing
    6 new Meiling rocker arms
    1 set new sealed power 10 over rod bearings
    1 set clevite77 20 over main bearing
    1 set std sealed power rod bearing
    1 single groove Walsh bottom crank pulley
    1 Johnson Hyd race cam
    5-6 Pinto and Mustang stock clutched and pressure plates
    1 D-Port bare head w/lifter bosses cut for soild lift cam
    2-3 main bolts w/stud for p/u tube
    3-4 Mustang oil pump p/u tubes
    1 new set crower valve springs for 597 lift cam
    12 used soild lifter studs and nuts
    1 used Esslinger lifter boss cutting tool
    2-used Pinto manual rack-n-pinions
    2 late model 2300 EFI Dists.
    You have a # I would like the header for the pinto, an the bare head thanks george
      Could I get a number to contact you? I want to buy a rack and maybe some other parts.
        2 Late Model EFI Dist-------SOLD------
          Also::
          8 gal. fuel cell less foam and cam...$20
          2 Afco bottom spring pads for leafs(Pinto) and 4 new long u bolts...$20
            1 Pinto Rack--------sold-----------
              Lifter boss cutting tool------------SOLD-------------
                can you call me 386-506-9117 tim need part
                need to call me please tim 386-506-9117
                Pinto L/F caliper
