1 used 29x19 howe radiator capless radiator w/oil cooler #16 an neck $225
1 new c&r double bypass radiator 31x19 $400
1 used complete exhaust system schoenfeld 1 3/4- 1 7/8 3 1/2 colector y pipe 4 inch w/muffler ceramic coated black 5 races on them $600
1 new pair howe 1 5/8 -1 3/4 3 ½ cross over headers $305
1 new 4in schoenfeld 27inlong muffler $62
2 new schoenfeld x pipes $155 each
1 new moroso spiral muffler 3 ½ 18inlong $66
4 new schoenfeld 13/4 31/2 collectors $38 each
1 new howe 10inlong 5in muffler $115
1 used coleman muffler 3 ½ y pipe 4” outlet 18”inches long $ 75
1 used howe muffler 3 ½ y pipe 5”outlet 18”inches long $75
1 used pair schoenfeld crate motor headers 1 5/8 1 3/4 3 “ collector $100
1 used rjs tall fuell cell 22 gallon w/can w/cap $125
1 used fuel safe short 22 gallon w/fill plate no can $175
1 used atl fuel cell 15 gallon w/fill plate no can $125
1 new rjs fuel cell 15 gallon no can $125
1 used ford 9inch with w/5 tubes. 69inch tube to tube no hub or axels $225
1 used ford 9inch 65inch tread width set up for 3 link 5x5 snouts $400
2 used Detroit lockers $450 each
2 used D.P.I. locking units $425 each
1 used aluminum gleason $675
1 new winters track $900
4 used koni 7 inch stroke steel body rebound adj shocks $200
4 used avo/qa1 9 inch strock comp adjustable shocks $150
10 used pro take apart steel body shocks 7inch/9inch $400
8 used non slotted shaft upper aframes screw in ball joint 0 and 10degree cups 8inch-10inch $20 each
4 used Outlaw/port city 4 piston billet brake calipers 2 fronts 2 rears $500
4 used willwood 4 piston billet brake calipers 2 front 2 rears $500
6 used coleman w/5 hubs $250
4 used willwood w/5 hubs with rotors and bearings $325
2 used coleman 5on5 alum brake hats with .810 rotors $100
2 new allstar performance 3 “offset steel brake hats $50
1 Used willwood hanging pedal assembly with master cylinders $125
4 used w/5 hub covers/ wheel alignment covers $40
1 used howe stealth hd steering quickner $100
1 used sweet 16:1 power steering box w/fittings $150
1 used agr 12:1 power steering box w/fittings $150
1 new stock gm metric power steering box $100
1 used Appleton manual rack n pinion $125
1 used 93 port city perimeter chassis with a 2006 lefthander stock camaro clip $1000
Used rear springs 5 ½ x 10/11/12/13 inches tall many rates and brands $25 each
Used front springs 5 ½ x 8/9/10/11/12 inches tall many rates and brands $25 each
Used coil over springs 2 ½&3” x 8/10/12/14/ many rates and brands $30 each
1 used ram 7 ¼ triple disk $100
1 used quarter master mag Low ground clearance bell housing with starter $600
3 used gm alternator’s with pulleys $50 each
2 used parker helmet pumps $50 each
1 used moroso plastic battery box $20
2 used jaz over flow tanks $10 each
2 used moroso over flow tanks $15 each
2 used splined rear sway bars and 1 pair of arms $100
*prices do not include shipping.
Pics can be taken of all the parts that are listed and sent to you. If you have any questions call Checkered Flag Racing at 305 769 3919.
