For sale new valve springs. still in car can hear run.$1800. 863 412 0218
602 crate motor
its 602 crate motor
Horsepower: 350 @ 5,000 RPM
Torque: 390 ft./lbs. @ 3,800 RPM
Max. Rec. RPM: 5,500
Compression Ratio: 9.1:1
Block: 10105123 Cast iron four bolt with 1-piece rear main seal.
Crankshaft: 14088527 Nodular cast iron.
Connecting Rods: 10108688 PM Steel
Pistons: 12361371 Cast Aluminum
Piston Rings: 14089025
Camshaft: 20502476; Lift: .435” I, .460” E; Duration @ .050: 212° I, 222° E
Lifters: Hydraulic Flat Tappet
Timing Chain: 14087014
Valve Cover:: 25534359 Kit With Breather Tubes
Oil Breather:: 25534355 Breather Kit
Cylinder Heads: 12558060 Cast Iron Vortec, 64cc combustion chambers.
Intake Valves: 10241743 1.94”
Exhaust Valves 12550901 1.50”
Valve Springs: 10212811
Rocker Arms: 10089648 1.5 Ratio
Rocker Arm Nut: 25534352 Special, ”Kool Nut Design”
Intake Manifold: 12366573 Aluminum High Rise Dual Plane
Distributor: 01104067 GM HEI
Valve Lash: Zero
Spark Plugs: R44LTS Gap @ .045, Rapid Fire #8 Gap @ .035
Ignition Timing: Max. 32° Total @ 4,000 RPM
Fuel: 92 Octane Unleaded Gasoline
Oil Pan: 25534353 8 Quart Black Powder Coated Circle Track With Oil Filter. It includes a full louvered windage tray, oil scraper, three trap doors, oil level plug, 8” deep sump, a 3-1/2” kickout on the right side, and a 3/4” oil pick up tube
