Parts,carbs,misc new engine parts forsale
  • Parts,carbs,misc new engine parts forsale
    Ford 9" complete 5:83 w/pinion support and yoke $300
    Mallory mag with box and storage case $225
    15 sets of valve springs 1.250-1.650 many applications-call or text
    Full manual tci turbo 350 raced four times have shifter, cable, Trans,converter $550
    600 v.s. Holley rebuilt $225, 650 v.s. rebuilt $225, 750 v.s brand new$325, 650 d.p. rebuilt$300, 750 d.p $300, 800 d.p $300
    20 used solid rollers$125
    F.t. 4 valve relief 5.7 rod coated pistons brand new$125
    3.750 eagle crank fits 350 mains with balancer $200
    Al long water pump with cooling lines pulleys and belts$80
    604 al heads with Manley severe valves fresh from machine shop$500
    Fuelie 2.02/1.6 fresh mech ready moly 10* $450
    4.56 allstar 10 bolt Chevy gear already new pinion bearing never assembled$100
    Many upper control arms afco call for prices many new ball joints in box call
    Big front racing springs 1-900 1- 1000 $40 both
    Many 2.500 coil over springs 175#-600# different heights-call
    386-837-8048 call or text is ok too. Can get pics if needed
    Forgot to add 1.5 GM roller rockers 7/16- $75
    2pc rear l-88 flywheels 10,000 rpm brand $75each
    Many wide five dirt latemodel spindles varying height and snout angles- call
    Two wildwood wide five hubs $70 each
    Set of 624 Chevy heads bolt on ready 1.250 springs to .540 lift Hyd $300 set
    Chris at 386-837-8048
      trans is gone thanks karnac and tom goodluck
        i also have a floater minus gear and no drive flanges has axels, hubs, long studs, rotors, it is a 9" and is 61" from hubface to hub face $150 needs bearings for hubs .
          Do you only have the 5.83 gear? What spline and spool is it? What part of Florida are you in? Thanks
            Trans for sale
            Hey i want a Bird Dog for hooking you up with Tommy P!!!
            Maguires Auto Repair
            Williston Fl
              williston - thanks for the hook-up, but i don't keep bird dogs in stock. LOL again thanks and I owe you one. Keep Doing The Right Things,Many people have Forgotten the do as you would want done to you Attitude. Let me know when you need something hopefully i can help.
