--World Products Sportsman II heads, 2.02/1.60 valves, Flat tappet springs with studs and guide plates. $550
--Brand New set of 1.6 7/16 Aluminum Roller Rockers $100 obo
--Brand New Comp Camps Double Roller Timing Chain Set $30
--GM Bowtie Heads 2.02/ 1.60 valves I believe one head has a cracked intake seat $400 obo
--062 Vortec Heads Fresh Stainless 2.02/1.6 valves and springs, needs screw in studs installed, break in time only and one stub started to pull out. $350
--Edelbrock 7116 Performer RPM intake for Vortec heads, $90 obo
--Edelbrock SBC Victor Jr Intake $125 obo
-- SBC 305 parts Block with one cracked cylcinder needs a sleeve, Luaniti 5.7 Rods new ARP bolts, JE Pistons .060 over, Aftermarket stock appearing crank, Assembly is ballanced $1000 obo
-- Stock 059 305 vortec heads, $225
--Mittler Bros 9" Rearend, 63" wide offset for a modified, hubs, axels. rotors $175 obo
--3 Turbo 350 Automatics out of pro trucks, 1 in perfect condition only 2 races on it, 1 has cracked bell housing but internals are still fine, 1 needs to be rebuilt, 2 10" PTC torque converters $750 for all obo
--Winters Triple Track Differential (Aluminum Gleason) for Quick Change $400
--AGR 14.1 Steering Box like new only 3 races on it $200
-- Holley 750cfm Carburetor built by McLendon Racing Carbs $350
-- 20+ Aero NASCAR wheels, 5x5 4 1/2 offest. $200 for all obo
--5.83 9" Ford gear lightened $75
--Kirkey Racing seat with leg braces, shoulder braces, and custom head and neck supports. with black cover $100 obo
--Impact 5 point seat belts 08 dates, $45
--Various 5 ½”x 9.5” front springs, 600lb-1000lb all have been rated with Intercomp digital spring rater $10 each
--Various 5"x13” rear springs 125lb-350lb all have been rated with Intercomp digital spring rater $10 each
--Spring rater for checking rates of racing springs. $150 obo
--Pair of Simpson Fusion Driving shoes, size 10.5 been wore one time wrong size, $90 obo
--2 10.5” Clutches for Eternal balance SBC (Crate Motors) Both have RAM Billet Steel Flywheels one clutch has 12 races on it 10 Spline The other has 3 races 26 Spline, these meet the 32lb clutch rule, $150 each obo
--5 10.5” Fine Spline (26) clutch discs. $50 for all obo
--Champ claimer oil pan for 2 piece rear seal SBC $50
--Holley Fuel Pressure Regulator with bracket fittings and gauge, $25 obo
--58” Ford 9” rear end housing, Nickle plated, has hubs and bearings $175 obo
--9” Ford center section gaskets 15 in all $15
Pictures available on request Items located in Huntsville AL, will ship at buyers expense 256-655-7109
