Street Stock / Bomber parts
  • Street Stock / Bomber parts
    Lots o' stuff accumulated over the years:
    Full size 8.5" monte carlo rear ends:
    3.73, locked, 1/2" studs, axles magnafluxed before assembly. Sitting long time. Rear cover rusty, but gears ok. $150
    3.08 (I think), bolt in axles (Gran Prix), locked, 1/2" studs, axles magnafluxed before assembly. $100
    Heads:
    441: 1.94/1.5 stainless valves. Sitting long time on OSW super stock motor (only a few races before parked), so will need springs. Probably should be freshened up. $150
    462: .550 lift springs, 1.94/1.5, screw in studs. Virgin ports. 10 races on an asphalt modified. Sitting on shelf many years. $300
    305 heads: drilled for screw in studs. mismatch #s. $50
    Stuff:
    .450 lift street stock cam. Broke in, then pulled out. (motor went in the bomber) $40
    3.73 7.5" GM ring and pinion, $50
    3.73 metric rear with mini spool. $150
    Mini spool for 8.5" GM. $30
    '68-72 Chevelle stuff:
    Summers Bros 12 bolt axles with C-clip eliminators. $100
    Lower control arms. $50 pair
    8.5" (they do exist) 2.73 rear with bolt in axles. Dirty. $150
    Stock 3.31 rear. ('64) $100
    Disc brake spindles and rotors. $150 pair
    Will probably list more stuff as I find it.
    John 321 331 7100
    Update
    3.73 metric rear sold
