Here is a set of Wide 5 hubs by DPI/Sierra with the 4 piston caliper rotor offest.  The right front is aluminum while the others are magnesium.  They have 1 1/4" directional vane rotors for the front and .810 straight for the rear.  The Wilwood aluminum drive plates include bolts that are drilled for safety wire.  The Coleman dust covers are the type that accept a magnetic caster camber gauge.  The spindle nuts are the aluminum slotted lock type and are inside with the inner and outer bearings.  The studs are coarse thread and include the lug nuts.  This is a good set of hubs that just need cleaned up and the bearings repacked.  $250.00  407-832-5237  Buzzy  Winter Garden  If you're into Ebay, please check out my store@hot set up racing equipment, seller name oldsrolls
Wide 5 Hubs
