World Product Heads Part #043610: 67 cc Combustion Chamber, 170 cc Intake Runners, 1.94 Intake Valves, 1.50 Exhaust Valves, Machined for screw-in studs: $400.00
New Ford 9" 31 Spline Mini Spool: $20.00
Used Moroso Aluminum Valve Covers: $10.00
Used 420 Lift Comp Cam (Still like new) with matching lifters: $25.00
Eldenbrock 2101 Aluminum Manifold: $50.00
Victor Jr. 2901 Two bbl. Intake: $100.00
Ford 9": 543 Gear with Mini Spool (TWO RACES ONLY): $275.00
600 Gear Light Weight Full Spool (Five Races ONLY): $325.00
633 Gear Light Weight Full Spool: $325.00
525 Gear Light Weight Full Spool (TWO RACES ONLY): $350.00
620 Gear Light Weight Full Spool: $300.00
583 Ring and Pinion Only (TWO RACES ONLY): $100.00
683 Ring and Pinion Only: $75.00
3 Speed Saginaw Transmission (1.68 2nd Gear, New Bearings): $150.00
For the springs: $25.00 EACH or $180.00 for ALL
5" Rear Coil Springs (AFCO/INTEGRA): 150 lb, 225 lb, (3)250 lb
5" Front Coil Springs (AFCO): 800 lb, 850 lb, 900 lb, 1000 lb
For the shocks: $20.00 EACH or $150.00 for ALL
(2) WB946, WB945, WB94, WB95, WB746, (2)WB75, WB77
2: 15"x8" (3" Offset) Bassett Wheels: $15.00 Each
2: 15"x8" (4" Offset) Bassett Wheels: $15.00 Each
FOR ALL ABOVE PRICES IT IS O.B.O. If you are interested in any of the parts above please send an e-mail to us at loweracing57@aol.com or send a private message here on the forum.
Thanks,
Timmy Lowe Racing
Thanks,
Timmy Lowe Racing
