Dillon center section with a 99 Lefthander coil over front clip with 2011 updated front end geometry. Howe adjustable upper ball joints and titan low drag lower threaded ball joints. 2010 Lefthander style rear clip. Has long RR trailing arm and the pan hard-bar is moved ahead on the rs. 2010 Fivestar Monte Carlo ABC body with light weight roof. Wilwood 4 piston brake calipers on all 4 corners the fronts have therma lock pistons PFC rotors on the front Wilwood scalloped rotors on the back. Wildwood hubs on all 4 corners with low drag hub seals. Hawk pads all the way around with AP PRF brake fluid. Cnc brake and clutch pedal assembly with Cnc brake and clutch master cylinders. Fuel safe bladder style 15 gallon fuel cell with quarter panel filler. New optima battery. M.E.P. 604 Chevy crate with ati balancer scorpion rocker arms Gilmer style pulleys agr power steering pump with built on canister Peterson remote oil filter adapter. Afco 27 inch radiator with built in oil cooler. Quarter master 5 ½ clutch with reverse mount bell housing. Appleton rack and pinion with bump steer adjustable ends. Schoenfeld tri-y headers with schoenfeld exhaust system and muffler. Gforce south 2speed tranny with aluminum drive shaft. Winters quick change with 4:86 ring and pinion and aluminum spool. Auto meter gauges msd ignition. Butler built seat impact seat belts.
Car was stripped at the end of the 2009 season and completely redone by Checkered Flag Racing. New Five star ABC body was installed with new interior and foot box. New rear clip and trailing arm brackets were installed. New fuel safe 15 gallon fuel cell was also installed.
Motor has 500 laps on it valve springs have 50 laps.
Transmission has 500 laps on it.
Quick Change has 500 laps on it.
Brake calipers master cylinders and rotors have 500 laps on them.
Clutch disk have 500 laps on them.
Car set fast time and won 2 pro late model races this year at Punta Gorda Speedway.
Price $15000 turnkey would consider selling as a roller without motor and tranny or with our motor buyer’s choice. Comes with carrera rebound adjustable shocks and an extra set of carrera shocks, lower a frames spindles, extra set of wheels and anything else that goes with the car.
Call Checkered Flag Racing at 305 769 3919 or email us at cfrrace@att.net
