Ford 2.3 Mini-Mod Mini Parts
  • Ford 2.3 Mini-Mod Mini Parts
    No longer have a mod mini so need this stuff gone............
    (2)used sets Adjustable valve post and slugs---long post
    (2)used sets of just the adjustable post----short
    14 mouse traps 8 are new
    New set of 100" race engineering valve lash caps
    $100 for everything above.....
    D-Port open chamber solid lift head w/racerwalsh cam..cam is 450 lift I think.
    Stock size valves,racerwalsh springs.
    Been cut very little,head has been wrapped on shelf for about 5 years.
    ----------------$100 firm-----------------------
    (1)used set Esslinger head stud kit...$30
    (1)used set Esslinger main stud kit....$30
    214 Mustang trans with Mustang bellhousing cut for hyd clutch.....$75
    (1)used wiesco 30 over 5.7 rod piston w/wrist pin...$20
    2-3 different EFI to carb adapters for holley.....$25 each
    Highly ported EFI intake.........$35
    2.5 crank that needs turned...$10
    5 gal bag full of timing and alx shaft covers...$20 whole bag
    Mis clutch disc and pressure plates,some w/1 race on them...make offer
    Mis new engine bearings....make offer
    4-5 multi pattern 8x13 2" off set wheels w/outter lip damage...$20 each
    All the hoosier RC1 you want FREE............25-30 of them
    or make offer on anything above.....
    Sale Pending On Head.....
      Can u call me wanna pick up head tonight 863 651 4267
        Parts SOLD.
        Head
        8 mouse traps
        2.5 crank
        main and head stud bolt kits
        Thanks Karnac and Ray!!!
          Make Offer need gone.
          Also have 2-3 different size EFI intake carb adapters.
          13x8 different offset wheels,outer lip damage on most but usable.
            Has the head sold ? Do you have 2.14 transmission/bell housing ?
              we still have a stock head, and yes the 2.14 trans and bellhousing we still have also
                how far are you from citrus?
                  were at i-4 and 301 in tampa
                    parts
                    ill give you 100.00 for the 214 trans one of the efi adapters and a clutch disc and pressure plate
                      sounds good, just so you know the clutch and pressure plates are stock
                        ill need an addy and # ill come down on fri to pick them up
                          ill pm it to you
                            Transmission and Bellhousing----SOLD
                            Water Pump Pully-----SOLD
                            1 Crank Pully------SOLD
                            Thanks Real Racin
                            • #15
                              Still interested in the E.F.I. intake, did you get my pm?
                              50Gage. When you drive the high line, you don't hit the wall as hard!
