We are running a special on a complete short blocks to help racers get ready for the new season. You buy this kit take it to your engine builder and have it assembled and add top end,cam and your ready! We also have special on top end kits and great deals on aluminum heads.
Shortblock Kit Includes:
Dart fully machined and blue printed SHP block with 4 bolt center splayed caps with 1 or 2 piece seal, bored to 4.030 or up to 4.060. Special coated cam bearings from Dart are included, and they are very expensive.
Matching bore size forged Probe pistons. These are available in flat top style. Hastings plasma molly rings are included.
*PROBE FULLY FORGED FLAT TOP LOW EXPANSION PISTONS RATED AT 700+ HP THESE PISTONS ARE VERY RESISTANT TO THE DAMAGE CAUSED BY DETONATION COMPARED TO NON FORGED PISTONS. THESE PISTONS HAVE TWO VALVE RELIEFS. PROBE PISTONS ARE 100% MANUFACTURED IN THE USA. THEY ARE ONE OF THE HIGHEST RATED PISTONS IN THE COUNTRY
Scat 9000 series crankshaft. The rotating assembly is fully balanced to less than 1 gram. You will be given a balance sheet with your assembly.
*Scat 9000 Series Crank Features:
Made from an exclusive Space Age cast steel material for strength
No more hassles with poor quality OEM crankshaft cores
Knife edged counterweights
Straight shot oil holes for improved high RPM oiling
Precision ground and micro polished. RPM Rating: to 7000 RPM
fully forged I beam rods with cap screws. Rods have been stroker clearanced, and sized. These are a bronze bushing (full floating) design. 5.7 inch. Approx weight 560 gram + or - 1 gram. The benefits of the bushed end are well known.
King bearings, sfi approvable flexplate, Pro Race damper, brass freeze plugs.
Order today! $2999.99 Contact Savage Performance at 813-484-5173
