I got two 10 inch sportman dirt tires hoosiers would be good for thunder stock or sportsman comes with rims 5by 4.75 $ 40 each
NSS 8 inch hoosier treads all are in great shape i got 5 of them at 25 each tire
fan shroud $10
18"steel 4 blade fan $10
three racing air breathers $5 each
one master cly with short rod to bypass booster $15
9 1/2 racing springs 850 and a 750 $15 each or $25 for the set
Two 15x8 rims one is 4 in backspacing and the other in a 2 in backspacing $10 a rim
I got a three cast iron 4 barrel intake ill take $15 each .
Set of upper motor mounts $5
big sway bar 2inoff a big monte super stock $5
2 sets chrome tall vavle covers new with chrome aircleaner $25
2 full size monte carlo driveshafts and also a big sway bar that almost 2inches around that fits big body monte $15 each
a set of big body gm upper a-arms $15
one center dump exaught manifold $20
Stock monte ss floor shifter $8
two alum. angle spacer they go from 2 inches to 3 inches $20 each
one master on and off switch $10
Exauht for center dump manifolds goes from 2 1/2 inch to 3 inch $15
79 cutlass alum. hood $40
79 cutlass rad. support and headerpanal with all lights $40
chevy 350 5.7 rods with dish pistons came out of a motor wit only 50,000 on it $40
Stock 1974 oil pan and vavle covers $20
Stock replacement waterpump for chevy 350 $15
stock fuel pump in well working condition came of a 74 vette $20
Side lexan windows for a mid 80's montecarlo, grand prix $10
also had a throtle rod $5
Hi voulme fuel pump $ 20
New comp cams thumper cam
this has very little time on it. Looks brand new. lift is .513/.498 adv dur: 283/303 lobe sep:107.0 $60
12' 35o turbo torque convertor $45
fan shroud $10
