Here is a pair of the Metric Monte Carlo style spindles like the ones that are being used on the Dirt Mods and Pure/Hobby stocks. They have been drilled for the 5 X 5 bolt pattern and have 5/8 coarse studs. The lower taper is stock and the upper has been reamed for the standard tubular a-frame ball joint taper. The tie rod hole has been drilled for a 5/8 bolt and they accept the small GM Metric calipers. The bearings have been packed with LE synthetic grease and they are togather and ready to bolt on. $100.00pr Buzzy 407-832-5237 Winter Garden If you're into Ebay please check out my store @Hot Set Up Racing Equipment, seller name oldsrolls.
Metric Spindles
