I sold my mod mini which was the black #3 which won 17 out of 24 but they only wanted the motor that was in the car. This motor I'm selling has all the machinework already done by Vannaman Racing Engines and has already been blueprinted.Remember everything in this engine is "BRAND NEW". It has 5.7 carillo rods,U/L gasport wiseco .30 pistons,zero gap total seal metric rings,U/L piston pins,Calico coated King rod and main racing bearings, Small journaled balanced crank,turbo high volume oil pump,C-Line 7 qt. rear sump race pan,U/L round tooth Race Engineering pulley kit with blue Kevlar belt,billet race belt tensioner,oval port D9 head with crane 510 cam,U/L retainers,triple spring valve springs,Ferrara Valves solid rockers with mousetraps. The head has been cut to the intake threads and is one BAD HEAD.Comes with stock intake of your choice with a Johnson machine Carburator .Install a distributor and go racing.This is the sister motor to the one I had in the Racecar but never had to use it. I have over $5500 in this motor which had 240 HP on the dyno and I have Recipts to show for it. The motor needs to be reassembled since blueprinting. I will sell it assembled for $4500.00 or you can assemble it yourself for $3700.00 may trade for a boat or vehicle of equal value. Thanks for looking.
Steve Griffin ph#352-636-6048
$3000.00 and come take it all. This motor is all new. "everything"
