part have to go make offer the more you want the cheaper ill go
Two 15x8 rims one is 4 in backspacing and the other in a 2 in backspacing $12 a rim
comp cams 500 lift 2200-6500 303 dur 108lc $15
isky 525 soild lift cam and crane soild lifters 3000-6800 525 lift 296 duration 106lc $50
I got a three cast iron 4 barrel intake ill take 10 each . i got one alum stock 4 barrel intake ill sell for 20
I got a two barrel intake ill take 10
16 gallon fuel cell with foam and pick up 2' square tubing frame $35
Set of upper motor mounts $5
big sway bar 2inoff a big monte super stock $5
chrome tall vavle covers new with chrome aircleaner $15
i got a nice set of camal back head needs one vavle i took it out cause i over tightin the rocker and mushshomed the top of the vavle but other then that they are bad ass 4 angle valve job 600lift valve spring cut to 62cc they got screw in studs and guide plates $230
set of monte carlo doors off a mid 80's monte carlo $50
