MSDŽIgnition Upgrade & Rev Limiter Optimizing Bundle Offer
Are you still running a stock MSDŽIgnition box in your racing program? Have you ever wondered how the top racers always seem to have an edge on the rest of the field? They always have the best options in their racing program ready to do battle. The first thing available for your MSDŽIgnition box, is to install a matched pair of main amplifiers and some associated parts to make the box react quicker to triggering input. The result of this single change is a quicker launch of the race car off the corners; this improvement is effective from 3300 to 9000 rpm. The second change is to make adjusts to the Rev Limiter circuit so it will operate at the very top end of the allowed One percent margin rpm limit of the Rev Chip run mandated by many sanctioning bodies. If your driver likes to lean on the Rev limiter during the race, it will allow them to get back an avg. of 200 more useable rpm. It also rises the starting point of when the Rev Limiter circuit starts to kick in; most racers dont realize that the Rev Limiter circuit starts in 175 rpm lower than the RPM marked on the Rev chip. Another issue not commonly known, most current chips are running at least 109 rpm lower than the number marked on the Rev chip. So as a racer your giving up a lot of top end usable engine rpm during a race due to tolerances being to loose. If youre running a class that is very tight, then consider having your MSDŽIgnition box given the winning treatment. The total cost of this bundle offer is $150.00 which includes return shipping.
ep33510
704-995-4286
ep33510
704-995-4286
