part have to go make offer the more you want the cheaper ill go
Two 15x8 rims one is 4 in backspacing and the other in a 2 in backspacing $15 a rim
comp cams 500 lift 2200-6500 303 dur 108lc $20
crane cam 500 lift 2000-6500 292 dur 106lc $30
isky 525 soild lift cam and crane soild lifters 3000-6800 525 lift 296 duration 106lc $70
I have a set of 882 head cut to 72cc 194 160 vavles 550 comp vavle springs honed out alittle and re shotpeened at machine shop $ 175 ready to bolt on
I got a three cast iron 4 barrel intake ill take 10 each . i got one alum stock 4 barrel intake ill sell for 20
I got a two barrel intake ill take 15
16 gallon fuel cell with foam and pick up 2' square tubing frame $40
Set of upper motor mounts $5
big sway bar 2inoff a big monte super stock $5
one flex fan $10
chrome tall vavle covers new with chrome aircleaner $15
i got a nice set of camal back head needs one vavle i took it out cause i over tightin the rocker and mushshomed the top of the vavle but other then that they are bad ass 4 angle valve job 600lift valve spring cut to 62cc they got screw in studs and guide plates $300
set of monte carlo doors off a mid 80's monte carlo
one flex fan $10
