2)2300 stock blocks w/cranks.............$50 each
1)2300 boat motor block w/steel crank...crank turned ready to install........$100
1)215 Mustang trans.....................$75
1)10 lbs steel flywheel...................$50
10-15 Dirt 8x22.5 & 8x23-13 RC1 tires..........$10 each(50% or better thread)
1)brand new 8x23x13 RC4 tire(never put on car)........$75 on 13x8 wheel..$100
1)O-Port open chamber head,cut 180-200(to intake bolts) with ajd. lifter post,crower springs(600 lift),retainers,locks**no cam-followers**....$250--firm
1)Sweet racing rack**used on Mustang**..........$100
2-3 differant EFI intake-carb adapters 1 1/2,2'',both plastic,
1- 1 1/2 wood ...................................$45 each
Couple EFI intakes ported-polished----------------$50 each
3)lite 2.5 (273 grams) wisco pistons .30 w/Manley 5.7 rods..........$175
2-3 sets new RacerWalsh valve spring(stage2-3 springs)$40 set
Pile of timing covers(around crank),water pumps.......
1)Esslinger water pump...................$45
1)stock Pinto cross menber...............$50
1)set Boyd roll tube front frame rails...........$35
5-6 stock Pinto upper A-Frames...................$10 each
2 sets stock Pinto lower A-Frames................$25 set
1)older Outlaw4/Mod mini Tube chassis w/Pinto cross menber.
Has racing rear 6"arch springs,front a-frames spindles-rotors,springs.
**NO REAR**(former Chad Rose 7jr)...Great starter car or w/stock k-frame
could run on pavement as mod mini.................$250
LOTS AND LOTS of misc parts...............
