All parts are used!
Blowproof bell housing with adapter for different size chevy collars(?) bottom cut out $100
Saginaw 3 speed 1.68 2nd. Grinds a little going into 3rd gear but has done it since I've owned it-$100
#2101 intake painted black-$60
31 x 19 afco radiator. used but no leaks-$50
Aluminum water pump with Moroso crank pulley and aluminum top pulley w/ 15" steel fan-$75
Moroso aluminum tall valve covers with breathers-$75
Carter/cv billet fuel pump with 8an line to carb-$50
1.5 roller rockers-$100
Intercomp digital scales with home made ramps-
Longacre turn plates
Longacre toe plates with tapes
Speedway caster/camber gauge
Lead, lead and more lead-$1/lb.
5x5 steel rims mostly aero and bassets-4" and 5" back space-$25 ea.
mini starter-$50
Drop base offset air cleaner with K&N filter-$50
Air box for Holley 4412
Wilson carb adapter for 4412-$50
15 1/2 racing seat-$50
462 heads 2.02/1.6 new ready to bolt on-$500
World Products 72cc heads, bare-$200
9" chunks-4.71 and 6.00 28 spline full spools
9" gears- 6.20, 4.75, 5.25(lightened and chromed)
1 1/8" hollow Howe sway bar with eyebolts to convert your stock bar mounts. -$75
Prices are firm- I can send pictures. Listing this stuff on Ebay this weekend so if you want it, let me know
352.318.3912
mini starter-$50
352.318.3912
