started as a baked 010 block(high nickel content) bored 4.0305, decked .008, studs in 4 bolt caps and line honed .003. screen kit and lifter bores honed to clean up.pistons lightened to 452 grams,rods polished and balanced big and small end.piston pins upgrade to lightened howards. rings file fit with moly top ring. rhs 12402 heads.manley severe duty 1.94/1.5 valves. springs 98212 up to.570 lift installed @1.780 valve seal clearance.680 with seal installed moroso oil pump and gold moroso anodized pan and matching vented valve covers.comp roller rockers and arp studs stepped guide plated with trickflo pushrods,comp roller rockers with standard poly locks.oil pan has oil temp fitting.milodon windage tray oil pump pickup bolts safety wired.felpro blue gasket kit entire engine. arp headbolts and engine bolt kit. any questions feel free to call price is firm at $3000 intake to pan has waterpump and long pulleys,wix filter with aluminum solid oil filter adapter has been primed and valves adjusted. has 7qts of green penn breakin oil and comp cams zinc lube alredy installed. may breakin engine for you if needed needs plugs,carb,dist,wires for breakin so contact if interested at 386-837-8048 professionally building engines in PA for over 30 years so cam specs available at purchase and complete build sheet with purchase more info available.
UMP hobby/sportsman legal engine
