This engine is the one your engine builder can't build for the price I am selling it . $4000 carb to pan has 4340 howards 3.48 crank howards rods forged 4340 6" all h bearings. has howards mech cam.543/.563 on 106 lsa adv. duration 290/298 installed at 102. block decked.010 bored .060 platue finish n37 j87 stones. forged big dome spr pistons with je rings file fit with nitrous gap.milodon tray and studs and dual kickout circle track pan.moroso pump and pickup. direct lube mechanical lifters. has screen kit has 462 heads with bronze liners and manley severe duty valves 2.02/1.6 heads been decked .008 have been bowl hogged.700 intake pocket and .500 exhaust pocket with triple angle valve job also valves lapped before final assembly. has crane 99893 dual springs with 10* comp retainers and keepers viton oil seals arp studs with raised guide plates has 1.5 harland sharp 7/16 rockers with polylocks and stud guirdle. holley circle track valve covers with breather and blue felpro reusable gaskets victor jr with rear cooling lines has SMI 750 dp carb with 1" spacer. has msd 85551 distributor phillips wires around rear under headers autolite plugs 85's victor jr circle track water pump with pullys fan and spacer. cv waterneck bb type distibutor holddown with stud sfi flywheel or 10.5 lightweight type standard shift flywheel. rotating assembly balanced by Treiglers performance. This engine is in install ready tothe track ready has 85# oil pressure and is ready for CHRISTMAS be the first in your class to bring a front running engine out to play with the big boys. Interested parties call 386-837-8048 would cost over 9000 dollars to copy this build so if calling this is a ready to race engine already tuned already broken in and ready to win. Over 550 h.p. Engine was built with heat tabs.
358 13.2:1 comp chevy engine
