Chevy Motor Liquidation
  • Chevy Motor Liquidation
    Here is a list of Chevy motors that I am helping a widow liquidate. They are located in Moultrie, Ga. I have described them as best I can with the information available.
    1 362
    Block: 350 4.030
    Crank: Aftermarket 3.660
    Rods: Stock 5.7
    Piston: JE? Pop Up
    Comment: Looks like it was just assembled. $300.00
    2 393
    Block: 400 4.030
    Crank: Aftermarket 3.550
    Rods: ?
    Piston: JE? Pop Up
    Comment: Looks like it was just assembled. Has a stock pan. $500.00
    3 4.3 V-6 Busch
    Block: Bowtie
    Crank: Bryant
    Rods: Carillo
    Piston: JE
    Heads: Pontiac
    Intake: Brodix
    Cam: Crane Roller
    Rockers: Jessel
    Comment: This was a former Jimmy Spenser motor Mr Paige was almost done assembling. It has a dry sump pan. $2500.00
    4 427 Big Block
    Block: 289 2 bolt
    Crank: Stock
    Rods: Stock
    Piston: TRW Pop Up L2308 .040
    Comment: Looks like it was just assembled. $800.00
    5 406
    Block: 400
    Crank: ? Stock
    Rods: ? Stock
    Piston: JE Pop Up
    Heads: 492 SIS/G-plates Small Springs
    Rockers: Roller
    Cam: Roller
    Intake: Team G
    Comment: Stock pan like it was in a Street Rod $700.00
    6 393
    Block: 400 4.155
    Crank: Klien 3.625
    Rods: Carrillo
    Piston: Ross 2 Eyebrow Flat Top
    Heads: Aluminum AFR
    Rockers: Crane W/girdle
    Cam: Roller
    Intake: Team G?
    Balancer: ATI
    Comment: Mr Paige left the list of what is in this motor. It is a wet sump that was in the Late Model at one time. $2500.00
    7 350?
    Block: 350
    Crank: ? Stock
    Rods: ? Stock
    Piston: JE ? Pop Up
    Heads: 824 Open Chamber Small Springs
    Rockers: Roller W/girdle
    Cam: Flat Tappet/Hydraulic
    Intake: Torker
    Comment: Oval Track Pan $800.00
    8 4.3 V-6
    Block: Stock
    Crank: ? Stock
    Rods: ? Stock
    Piston: JE ? Pop Up
    Heads: Vortec
    Rockers: Stock W/poly locks
    Cam: Roller
    Intake: Stock
    Comment: Has MSD box and distributor. Was on the sled puller at one time. $500.00
    9 350 Vortec Long Block
    Comment: Stock roller motor. Looks like it was just assembled. Sold!
    10 4.3 V-6 Intake – Pan
    Comment: Tag says less than 100 miles after rebuild. $400.00
    11 305 Pan - Intake
    Comment: Tag say NEW crank/rings/pump/chain. It has been run, but maybe only on the stand. $400.00
    12 383
    Block: 400
    Crank: Stock ?
    Rods: Stock?
    Piston: 4 Eyebrow Flat Top
    Heads: 462
    Cam: Flat or Hydraulic
    Intake:: Performer
    Comment:: Has a stock pan. $750.00
    13 362
    Block: 350
    Crank: Bryant
    Rods: Carrillo
    Piston: JE ? 2 Eyebrow Flat Top
    Heads: Pontiac 23 Degree
    Cam: Crane Roller
    Intake:: Victor Jr
    Rockers: Jessel Shaft
    Comment:: This was a former Busch motor Mr Paige purchased from Gene Ross. It was fresh when he bought it and we’re no sure if he ran it in a car or just on the stand. It has been converted to wet sump. $4000.00
    14 454
    Block: 959 Stock
    Crank: Stock ?
    Rods: Stock ?
    Piston: .030 Pop Up
    Heads: Rectagle Port 990
    Rockers: Roller
    Cam: Roller
    Intake: Team G
    Comment: Mr Paige built this for a Drag Car he wasn’t able to finish. We don’t think the motor was ever cranked up. $2500.00
    15 327 Corvette Big 870 5/65
    Block: Small Journal
    Crank: Stock
    Rods: Stock
    Piston: Stock .030
    Comment: Looks like it was just assembled. SOLD!
    I have this list on several web sites and can't keep up with checking on them all, so please don't be afraid to use the telephone. Buzzy 407-832-5237
    Buzzy,call am interested in a couple of them
