79 Camaro virgin sub frame stripped $150
79 Camaro Lowers 2 right sides 1 left side $25 each
Uppers bolt in ball joints 7 3/4 shaft, length 7 3/4, 8 1/2, 9 1/4, 10 1/2 $20ea
long acre camber caster gauge in box $50
Stagger stick $25
1 3/8 sway bar $20
5 1/2 by 9 1/2 springs 845, 1050, 1050 $20 each
5 by 9 1/2 spring 950 $20
31 spline mini spool $10
600 Richmond ring and pinion new in the box $75
567 complete gear with mini spool 28 spline $200
633 complete gear polished full spool, aluminum yoke and tail shaft $600
9" stock pumpkins with gear (unknown) $40 each
9" low profile pumpkin containers $30 each
roughly 100 pounds of lead $1 per pound
1.5 ton Harbor Freight aluminum jack w/ receipt for extended warranty $30
1" quick torque lug tool $20
1/2 aluminum wheel spacers $10 each
602 crate motor valve springs, 1 race $20
Box full of stock Camaro steering components $25 for all
4 10" Chrome Light weight wheels 5 on 5 w Hoosier tires 2 races $200
several 10" wheels all in great shape 5 on 5 2", 3" and 4" offset $20 each
31 spline 9" axles 29" and 33" new in box $75 each
2 5 gallon fuel jugs square $10 each
Aluminum 14" stack-able jack stands Like brand new $200
Stock Camaro drive shaft $10
3 Pro shocks WB76 and 2 Carreras one is a 7/5 $10 each
Pro shock TA958 w/ quick connects brand new $50
Various swedge tubes $10 each
Located in Titusville, email edm111@earthlink.net or call 321 246 4104 and leave a message if no answer
The only trades that I may consider would be firearms and a 3:50-3:73 light weight 9" gear assembly with a posi unit.
Stagger stick $25
1 3/8 sway bar $20
