Go Back   Real Racin USA Motor Sports Forum > THE RACING CLASSIFIEDS > Wanted! - Equipment and Parts
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 01-18-2015, 10:10 PM
BobbyD1120 BobbyD1120 is offline
Sportsman
Default Trans for 2.3
Looking for a trans for a 2.3 ford mod mini that I can pair with a 3.27 rear gear to primarily run at NSS.
  #2
Old 01-20-2015, 12:29 PM
nss71 nss71 is offline
Sportsman
Default
Check your E-mail.
  #3
Old 01-20-2015, 03:25 PM
Lucky6 Lucky6 is offline
Super Late Model
Default Mod Mini Gear
Hey BobbyD just a question. What Tranny u looking for. If you are running at NSS that 327 gear will be to much un less you fine a 1.81 tranny. Good luck with that because they are very hard to fine. That will give you a final of 599. Just a possibility look for a 1.97 with a 273 gear should be around 537 final.
Sponsored Links
  #4
Old 01-20-2015, 06:57 PM
Sportsman
Default
Hey Lucky. Thanks for the response. I was looking for a 2.14 as I was under the impression the 2.14 with the 327 would work best for NSS. I have a spare 1.97 trans and a 3.45 gear. Would that work better or the 1.97 with the 327? Im just starting in this class and racing at NSS so Im trying to figure out the best options.
Quote:
  #5
Old 01-20-2015, 06:58 PM
Sportsman
Default
NSS71, I didnt get anything from you. You can also text me at 9047551848
Quote:
Originally Posted by nss71 View Post
Check your E-mail.
  #6
Old 01-21-2015, 09:40 AM
Super Late Model
Default BobbyD
Hey Bobby I have run at nss and had very good success, there. 1.97 with a 273 or a 1.81 with a 308 is the way to go. Any thing higher will turn to many rpms. For a 2300 motor u risk blowing up your motor. See if u can fine a 273 with that 1.97 or a 1.81 with a 308
Sponsored Links
  #7
Old 01-21-2015, 11:21 AM
Sportsman
Default
Thanks! Do you happen to know of anyone who has an extra set of 273's or where I could get a set? Based on your input I think Ill put in the 1.97 trans but now need to find a set of 273's
  #8
Old 01-21-2015, 06:45 PM
Super Late Model
Hey BobbyD just post on here that you are looking for a 273 gear for a mod mini. There are a lot of mod mini's out here and I'm sure that some body will have what your looking for.
Good Luck and I hope to see you out there soon.
P.S. are you going this weekend to watch the mod mini's run. I will be there to watch myself.
  #9
Old 01-21-2015, 10:03 PM
Sportsman
Default
Thanks Lucky for all your help and valuable insight. Ill get a post out there and hopefully find one. Yes, I plan on coming down this weekend for the race. I was really hoping to have my car ready but that's not going to happen. I will be down there so if you're around send me a text or call. Thanks!
Sponsored Links
Sponsored Links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
POWERED BY KARNAC.com since 1998
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright Real Racin USA & KARNAC Media 1997-2007
