#1
Old 10-01-2011, 08:08 PM
sidd65 sidd65 is offline
Late Model
Default Punta Fab/Pro 4 Rules
Anyone know where I can get the rules for this class? Are they running 8 inch tires now? If you have a copy of them can you send them to stegerracing@gmail.com. Thanks
  #2
Old 10-03-2011, 07:36 PM
philcesr's Avatar
philcesr philcesr is offline
Late Model
Default
They run 7" x 14" goodyear track tires which can be purchased at the track, 7 " racing rims allowed with no more than a 3" offset, all 4 rims must be same offset, 2400 lbs car and driver for single cam, 2500 lbs car and driver dual cam, must have 50lbs each side rear for total of 100lbs weight added for dual cam, that is part of the 2500 lb rule, can be no more than 54% left side weight, no more than 5 deg camber right front, all other wheels no more than 3 deg, stock 4cyl motor. you can get a copy of the rules at the track office, or email the track to get complete rules with safety, roll cage ect. and other specs detailed in rules, above is the main rules of the top of my head, if I can help otherwise let me know
Phil Ellis Sr
contact track at http://puntagordaspeedway.com/
  #3
Old 10-04-2011, 03:06 PM
Rick Williamson Rick Williamson is offline
Super Late Model
Question
Why is this in the complainers corner?
Sponsored Links
Sponsored Links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
POWERED BY KARNAC.com since 1998
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright Real Racin USA & KARNAC Media 1997-2007
