Go Back   Real Racin USA Motor Sports Forum > THE RACING CLASSIFIEDS > Racing Businesses
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 11-28-2011, 05:08 PM
checkered flag racing checkered flag racing is offline
Super Late Model
Thumbs up Used And New Racecar Parts
1 used 27x19 griffin radiator. $125
1 used 29x19 howe radiator capless radiator w/oil cooler #16 an neck $225
1 used 28x15 griffin rad 125
1 pair used dynatech under chassis street tock headers. $100
1 new pair howe 1 5/8 -1 3/4 3 ½ cross over headers $305
1 new 4in schoenfeld 27inlong muffler $62
2 new schoenfeld x pipes $155 each
1 new 4in flowmaster muffler 17in long $94
1 new moroso spiral muffler 3 ½ 18inlong $66
4 new schoenfeld 13/4 31/2 collectors $38 each
1 new howe 10inlong 5in muffler $115
1 new pair schoenfeld 185 street stock headers $186
1 used flowmaster muffler w/3”y pipe 4” outlet 17” inches long $75
1 used coleman muffler 3 ½ y pipe 4” outlet 18”inches long $ 75
1 used howe muffler 3 ½ y pipe 5”outlet 18”inches long $75
1 used pair schoenfeld crate motor headers 1 5/8 1 3/4 3 “ collector $100
1 used ford 9inch with w/5 tubes. 69inch tube to tube no hub or axels $225
1 used ford 9inch 65inch tread width set up for 3 link howe 5x5 alum hubs with drive flanges inner tube seals and axels. $500
2 used Detroit lockers $450 each
2 used D.P.I. locking units $425 each
1 used aluminum gleason $675
1 new winters track $900
1 used jegs metric rear end cover aluminum $30
4 used Outlaw/port city 4 piston billet brake calipers 2 fronts 2 rears $500
4 used willwood 4 piston billet brake calipers 2 front 2 rears $500
6 used coleman w/5 hubs $250
4 used willwood w/5 hubs with rotors and bearings $325
2 used coleman 5on5 alum brake hats with .810 rotors $100
2 new allstar performance 3 “offset steel brake hats $50
1 Used willwood hanging pedal assembly with master cylinders $125
1 used tilton hanging pedal assembly $100
4 used w/5 hub covers/ wheel alignment covers $40
1 used coleman steering quickner (old school) $30
1 used howe stealth hd steering quickner $100
1 used sweet 16:1 power steering box w/fittings $150
1 used cjr 12:1 power steering box w/fittings $150
1 used agr 12:1 power steering box w/fittings $150
1 new stock gm metric power steering box $100
1 used Appleton manual rack n pinion $125
1 used sweet power steering pump and reservoir w lines $150
1 used 93 port city perimeter chassis with a 2006 lefthander stock camaro clip $1000
Used rear springs 5 ½ x 10/11/12/13 inches tall many rates and brands $25 each
Used front springs 5 ½ x 8/9/10/11/12 inches tall many rates and brands $25 each
Used coil over springs 2 ½&3” x 8/10/12/14/ many rates and brands $30 each
1 used ram 7 ¼ triple disk $100
1 used quarter master mag Low ground clearance bell housing with starter $600
3 used gm alternator’s with pulleys $50 each
2 used parker helmet pumps $50 each
1 used performance products fuel filter assembly $25
1 used moroso plastic battery box $20
2 used jaz over flow tanks $10 each
2 used moroso over flow tanks $15 each
2 used splined rear sway bars and 1 pair of arms $100
*prices do not include shipping.
Checkered Flag Racing has been in business for over 25 years. We service cars for all types of racing scca, asphalt, dirt, drag racing, auto crossing, hot rods and many more. We have a full service racecar shop shock dyno, spring rater, fivestar body hanging fixture abc templates for fivestar and arp. Have a jig for metric clips, camaro clips, and tube clips for late models. We have shock program set up with bilstien shocks and heckman motorsports and a shock package developed for your street stock/modified/sportsman.
Pics can be taken of all the parts that are listed and sent to you. If you have any questions call Checkered Flag Racing at 305 769 3919.
  #2
Old 01-27-2012, 09:43 AM
Super Late Model
Default
tttttttttt
Sponsored Links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
POWERED BY KARNAC.com since 1998
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright Real Racin USA & KARNAC Media 1997-2007
